Problem with Timecode
  • Problem with Timecode
    I did a search here, and i looked in the help, I saw you could change it in the current preset, but nothing happens ? I can´t change the timeline timecode, it begins at 00:00:00:00 but I want it to begin att 09:58:00:00, so how do I change it ?
    A computer with a lot of stuff in it :)
    When you start your project in project settings you can put the start time code to whatever you want.
    Sr
      So you are saying, that I can´t change the timecode, with a finished edit, which has started at 00:00:00:00 ?
        NO that is not what I am saying.
        You can do the following
        When you have your project open right click on the sequence tap there you will see sequence setting go there change the time code start that is it.
          Ok, that is it, Thanks !
