Project Settings
  • Project Settings
    Captured several old VHS tapes. Which project settings should I use to edit 4.3 or 16.9?
    if the VHS is 4:3, I would use 4:3 because you can watch this with black pillars on a widescreen TV
    if the DVD/Blu-ray player is connected with HDMI, this will happen automatically
    if DVD player is connected via analogue cabling, you need to set the correct aspect on the TV remote
      Thank You Anton.
