problem HDV writing
  • problem HDV writing
    Dear Friends
    how can i write HDV file on dvd and which format i can export in edius timeline plz explain it can i write HDV file in movie factory software which software i can write HDV file on dvd
    plz solve my problem thanks
    Originally posted by santosh
    Dear Friends
    Do you want to make MPEG2 from an HDV timeline so that you can author and burn onto a DVD?
      Super Easy...
      Edit in HDV
      Change Project Settings to SD 16:9
      Check titles and PnP's
      Export compliant DVD files.
      Rusty
        yes fine freinds
        but what compression rate export 720x576 ya some other one if i can export 720x576 this is different of HDV ratio
          720x576 is correct for Pal DVD and be sure to select 16:9 in advanced options
          compression can only be decided by you because you know the duration
          if 120min than you will need to go as low as 4800kbps total including audio at ac3 256kbps max
          if 90 min, then 6500kbps total
          if 60 min, then 8000kbps total
          if less than 60 min then also 8000kbps total
            if i can export 1080i/50i (1080 lines,progressive,25fps) so how can i write it on dvd and which software
              When you apply for a change in the DVD specs and it gets approved???
              I think you got some good advice. If you want 1080 you better go to Blue ray disk.
              Blu-ray FAQ with answers to common questions about the Blu-ray Disc format. What is Blu-ray? How much video and data can you fit on a Blu-ray disc? Will Blu-ray be backwards compatible with DVD?
              SR
                sir
                i am in india here is no blu ray so how can i write 1080i because HDTV is available so how can we see the HDTV on HDv format
                  sir
                  If there are no Blu-ray burner there yet, and if you want to see your HDV footage on your HDTV, you can burn your HDV footage straight onto a standard DVD as data file, max is about 25 minutes, and this DVD will play on a Sony Playstation 3, now if you don't have a Sony PS3 there either then you are sol, but I guess you can still hook up your HDV camera to your HDTV and play it from your camera. (-:
                    SR
                    Hey SR, where does one get at Blue ray disk?(-:::
                      HERE:
                      Scroll down. :)
                        Yeah I see a bunch of blu-ray disc, but I don't see any blue-ray disk. (-:::
                        Sorry man, my Edius is Batch capturing right now, got some free time.
                          He he :)
                          SR
