I'd think it would be wise if you had an offline file above an online file, that EDIUS should render the underlying ONline file instead of rendering a checkerboard when exporting.
Seethrough offline clip
Originally posted by GrassValley_SL View PostI don't think that would male a lot of sense. The indicator is there to warn you that the clip in your edit is off-line.
If you don't need the clip in your output delete the offline reference because in your scenario it seems that you have no use for the warning.
Or disable it with 0 (zero)Gigabyte Z77X-UP4 TH, Intel Core i7 3770k 3.5GHz, 4 Core, 8 Threads, 32GB RAM, NVIDIA GeForce GTX 660 2GB, 500GB SSD HDD for OS, 40TB Usable Hard Drive Capacity, Window 10 PRO 64-bit Edius 9.5 WORKSTATION...
Really it does not make a lot of sense.
If you are exporting and you see it you know where it is on your timeline.
Also during the edit you must see it. Kind of impossible to miss it.
But you can submit a feature request how to is described in this post:
ThanksLast edited by GrassValley_SL; 05-15-2014, 05:01 PM.
Originally posted by GrassValley_SL View PostReally it does not make a lot of sense.
Actually, exporting checkerboards is what doesn't make sense. WHY on earth would someone want to export offline checkerboards? If there is an online file beneath it, why not use it for export?Gigabyte Z77X-UP4 TH, Intel Core i7 3770k 3.5GHz, 4 Core, 8 Threads, 32GB RAM, NVIDIA GeForce GTX 660 2GB, 500GB SSD HDD for OS, 40TB Usable Hard Drive Capacity, Window 10 PRO 64-bit Edius 9.5 WORKSTATION...
Originally posted by GrassValley_SL View PostLets agree to disagree . The only way to go about it is to submit a feature request.
Sorry
The request has been made years ago, by myself and others. (The request was for Edius to show us exactly on which timeline the offline clips are on and not just a timeline count).Gigabyte Z77X-UP4 TH, Intel Core i7 3770k 3.5GHz, 4 Core, 8 Threads, 32GB RAM, NVIDIA GeForce GTX 660 2GB, 500GB SSD HDD for OS, 40TB Usable Hard Drive Capacity, Window 10 PRO 64-bit Edius 9.5 WORKSTATION...
Originally posted by GrassValley_SL View PostSorry that is something different from what you are asking now. :)Gigabyte Z77X-UP4 TH, Intel Core i7 3770k 3.5GHz, 4 Core, 8 Threads, 32GB RAM, NVIDIA GeForce GTX 660 2GB, 500GB SSD HDD for OS, 40TB Usable Hard Drive Capacity, Window 10 PRO 64-bit Edius 9.5 WORKSTATION...
Originally posted by zvit View PostI'd think it would be wise if you had an offline file above an online file, that EDIUS should render the underlying ONline file instead of rendering a checkerboard when exporting.
Edius only does what the editor tells it.
If clips are ignored, isn't that as bad as checkerboards?Rusty Rogers | Films
Originally posted by Rusty View PostAre you implying Edius should take the place of an editor's diligence to assure that assets used are ignored?
Originally posted by Rusty View PostEdius only does what the editor tells it.
If clips are ignored, isn't that as bad as checkerboards?Gigabyte Z77X-UP4 TH, Intel Core i7 3770k 3.5GHz, 4 Core, 8 Threads, 32GB RAM, NVIDIA GeForce GTX 660 2GB, 500GB SSD HDD for OS, 40TB Usable Hard Drive Capacity, Window 10 PRO 64-bit Edius 9.5 WORKSTATION...
IMO: offline-clips should not be part of TL. Sorry, thats to sophistic IMO.
kurtHW: ASUS Z170-A; Proz: i7-6700K; RAM: 32 GB DDR4; GPU: RTX-3070, 8GB GDDR5; SSD: SAMSUNG-850-Pro, 500 GB
SW: WIN-10/64 PRO (22H2-19045-2364), Firefox u.a.
NLE: EDIUS-X(10.34.9923)-WG; RESOLVE-18.1.2.0006 Studio
// Read > Test > Understand
Originally posted by kpot View PostIMO: offline-clips should not be part of TL. Sorry, thats to sophistic IMO.
kurtGigabyte Z77X-UP4 TH, Intel Core i7 3770k 3.5GHz, 4 Core, 8 Threads, 32GB RAM, NVIDIA GeForce GTX 660 2GB, 500GB SSD HDD for OS, 40TB Usable Hard Drive Capacity, Window 10 PRO 64-bit Edius 9.5 WORKSTATION...
But then most people don't edit the way you do, they either use the original file or use the re-encoded oneDVC Built Clevo P775DM3-G Laptop with UHD screen, 7700K [email protected], Geforce GTX 1060 6GB GPU, 500GB M.2 Primary, 1x 480GB SSD, 1x1TB M.2, 1x 2TB 5400RPM Video drives, external Blu-ray Optical
Originally posted by zvit View PostI agree. So would you be happy to waste an hour searching for the offline clip, even though you know that the original clip is right bellow it and can be used instead?
Also If the files are off line why not restore them? That would be an easy fix.Last edited by GrassValley_SL; 05-16-2014, 09:57 PM.
