Does Edius package a titler that works?
  • Does Edius package a titler that works?
    Today must be Halloween for Edius titlers. First I had problems in TMP creating a credit roll ( as referenced in my other post). After I got a workaround and got the project done I decided to do some prep work on a Same Day Edit I have coming in December.
    I like to prepare titles and put them on V3 for reference when editing and to build a shot list from. This is all explained in the videotutorial I did here in case you are wondering.
    http://www.eventdv.net/Articles/Read...rticleID=37841
    I start building the titles this time in Quicktitler since I hear it is a nice simple to use titler and all I need are some simple titles explaining the shots I envision matching my music. After a few titles Quicktitler crashes when I try to save the title. After I force Edius to crash itself with CTRL+ALT+DEL I reopen the project only to find Edius now crashes when I try to access the title folder.
    What gives....does both the Quicktitler and TMP not work properly? Guess I am just having a bad "titling" night.
    This is one set of "titling" bugs I will sure be glad to see fixed. I love Edius and brag about it to everyone but right now it has me frustrated.
    Version of Edius?
      Originally posted by SRsupport
      Version of Edius?
      Sorry .... the latest 4.52!
        Can you give me the steps to reproduce the crash you are experiencing with quicktiler.
        1 Is there any info on it in the event viewer?
        2 Or do you get any message?
        3 What overlay mode are you using.
        SR
          SR
          Quicktitler would work fine for awhile and then all of a sudden it would lock up on a save function when returning to Edius. After reloading Edius the titles would cause a problem.
          1. Not real familiar with evenviewer. Edius doesn't crash enough to have had to worry about it in the past. :-)
          2. No message...the save process locks up and you need to kill Edius to get your computer back.
          3. Direct3d9.
          After messing around last night I did learn Edius would get stable again if I removed the title folder and re-imported all the titles. I did finally get everything done but it was a frustrating nite. One of the first I have ever had with Edius.
          I don't use lots of titles...usually one or two per project and they usually work fine. For SDEs I use them as my shot list and need more and this is where the problem started.
