Quick Titler Problem with Script Fonts
  • Quick Titler Problem with Script Fonts
    I've come across a problem with Quick Titler and some script TTF's. When trying to use some script fonts [eg HansHand], it looks fine in the preview window on the right above the font selection title drop down bar but when typing it in I get the default sans font appear.
    Note the fonts referred to all work fine in Photoshop etc.
    Is anyone else having this problem?
    Thanks in advance
    I came across this problem once when a TTF font was not installed via the control panel/install new font method, however I have no QuickTitler experience
      I usually just copy the fonts straight in the windows/fonts folder but your method does the exact same ting, I assume, because it made no difference. Quick titler still fails to draw the typeface correctly.
      Maybe the metric spec or something similar is missing in the TTF.??
