Title Motion Pro How do you do a simple scroll?
  • Title Motion Pro How do you do a simple scroll?
    Is there any tutorial anywhere for Title motion Pro? I just need to figure out how to do a simple scroll up.
    Thanks,
    Jack
    select Roll from dropdown near the top and "Bob will be your Uncle"
      Tutorial for TMP
      Actually, you can open help in TMP once you open it (file, new,Title Motion Pro). It is actually quite thorough if you search (index).
      Andrew
        Be advised that if you are using 4.52, there is a bug in TMP that causes a crash a lot of times if you try to use roll or crawl.
