Combining Projects in Edius 4
  • Combining Projects in Edius 4
    How can I or is there a way of combining projects on the timeline? i.e. importing one project behind the other.
    I have 17 projects that need to be combined into one project.
    Thanks,
    Ted
    Just create a new project and go File ->Import Sequence and browse for the projects you want to combine one by one
    Aristotelis Bafaloukos
    BEng (Hons), MSc, MBCS
    Ctrl+Alt+Delete
      Importing Projects
      Thanks,
      Ted
      Thank you for the suggestion. That works. The only problem is that the projects can no longer be modified because it's all embedded into one line. Or am I missing a step?
      Thanks,
      Ted
        Hi Ted
        You can open and modify each sequence seperately...the changes will automatically pass into your final sequence
        Ctrl+Alt+Delete
