I wasn't able to get this method to work. When I apply a preset, it just puts back the original filter. i.e. If the preset is a color correction, then when I apply the preset to a clip it just ends up being a color correction. This is in EDIUS 7. Was it different in earlier versions or am I just not creating a preset right?
An EASY way to redo color grading of Multi-cam AFTER compress to track?
When a preset is applied to a clip you will NOT see the preset name. The filter or filters that make up the preset is what you will see. The color correction you are seeing is the filter in the preset but it has all of the changes that you created so you ARE applying the Preset... you just are not seeing the preset name :)
MikeComment
