Print DVD is grayed out
  • Print DVD is grayed out
    I am using 4.52 with Storm. When I try to launch the Print DVD function it is grayed out. I have set in and out points. What else do I need to do to enable print tp DVD?
    Bob
    Computer
    Case Antec P180 - MB Intel 975XBX2 - CPU Intel Q6600
    Memory 4 gig DDR2 800 - 2 Drives SATA 300 + 500
    Video Card Nvidia 8800 GTS 320
    Are your Project Setting SD?
    HD settings are not DVD compliant!
    That's usually it!
    Rusty
      Make sure your project setting is not HD
        Print DVD Problem
        My project is set at 720x480 29.97 over 59.94i 16.9. I assume that this is SD. Presently I am not editing any HD.
        Bob
        Computer
          Is your out before you in point by any change?
            Change the project to 720x480 59.94i 16:9,
            then you can select Print to DVD
            Bob
              That was the key I changed the project settings and it worked fine. Thanks for the help
              Computer
