Mouse Wheel Crazies!
  • Mouse Wheel Crazies!
    What is this... ?
    On more than one machine, and more than one occasion, when I use the mouse wheel to frame-advance on the Timeline the Timeline plays beginning at super-slow and speeding (or slowing) with each mouse wheel advance. As if I were using Ctrl+J/K/L!
    This is something that I can't duplicate, but seems to happen at random, and no... I haven't changed the keyboard shortcuts.
    Confused and annoyed, Rusty
    Hi Rusty
    Yes I have seen exactly this behaviour too (starting from before v4.5). As you say it occurs randomly, although I have a suspicion that it may be related to the complexity of the timeline.
    Regards
    Andrew
    Andrew Pinder
    www.chpv.co.uk
      Just for fun-zies... the behavior has now stopped!
      Somewhat less confused and annoyed, Rusty
        That is a feature, when you press down on the wheel, and then scroll, it will go into j k l mode, so you guys must have accidently push down on the wheel before you scroll.
          I now see the mode you mention, but my mouse requires serious pressure for a wheel-click. I'd have noticed that.
          Rusty
            No, when I have seen it it was definitely not due to over-pressure - I can feel the difference. In fact I have seen similar funnies on occasions with my ShuttlePro, with the cursor continuing to travel long after I have stopped winding the wheel. It does not happen often enough for me to get upset about it though.
            Andrew Pinder
            www.chpv.co.uk
              This could be related to the scroll settings of your mouse => an example: check the settings for "accelerated scrolling".
              Edius X - Edius 9.52 Pro - Win 10 64 - AMD-Ryzen 9 3900X - 32 Gb DDR4 - ASUS-PRIME X570-PRO - Nvidia GeForce RTX 2070 SUPER - SSD M.2 1000 Gb system + 3 x 3 Tb storage - 2 x 23" Full HD Monitors - M-Audio Studiophile AV40
