capture settings
  • capture settings
    I am pretty new to this but here's my question- I need to know what settings to use to capture my home video's. I have about 40 hour long tapes (ntsc standard DV) that I want to capture and put on a hard drive for archiving and editing. What file format would I want to capture them so that I would have high quality and the files would be compatible in the future even if I wasn't still using a Canopus product. Any idea how large one hours file would be?
    Thanks for your help!
    For maximum compatibility, capture as Microsoft DV (there is a tradeoff in quality vs. capturing with Canopus DV, but your footage will go places where Canopus DV sometimes can't).
    DV is approx. 12GB per hour. So 40 hours is roughly 480GB - nearly half a terabyte!
      Kenneally I'm still confused with that...Can you please explain...I have read that the only difference between Microsft DV and Canopus DV is just headers and footers...
      Aristotelis Bafaloukos
      BEng (Hons), MSc, MBCS
      Ctrl+Alt+Delete
        Aristotelis The quality of the CODEC used by Canopus is superior to the quality of the msdv codec itself
        This is evident when files captured using msdvavi and then encoded to meg 2 files for dvd authoring
        If
        You capture to the Canopus dvavi then do the same the end product will be sharper and seems to have less motion artifacts / jagged edges - you can see this on larger TV's
        If you have the means capture and edit in the canopus file format for your tv system - ntsc in your case.
          Actually yes, my mistake - I was getting my YUV/RGB argument confused with storage format. That's more to do with what gets done to the footage within an NLE. Not the codec format.
          As it is these days, there is little difference in the two for capture and archival. It's all about the editing and processing.
            so microsoftDV is the way to go? Since I am using eidus to edit with for now, will the process be any slower with the MSDV format? What format should I output my final movie again to be compatible in the future?
              Processing will be the same essentially, since the data rate is still the same (DV).
              I only suggested MSDV since you said you wanted to include the possibility of not using a GV/Canopus solution in the future. Using MSDV ensures this.
                I realize this sounds absurd, but can you please walk me through the process? I assume I capture in edius with NHX-E1 SD NTSC for the project setting. I select with the capture pulldown the right input NHX-E1 DV. Where is the capture settings to select microsoft DV?
                  Edius can't capture Microsoft DV, you need to use optional software such as Scenalyzer (not free) or DVCapture (free from canopus.com registered user download area)
                    Also DVCapture will only work with Windows XP. SCLive is essential for DV, I highly recommend it.
                      Edius can't capture Microsoft DV, )
                      It can be done in EDIUS
                        I know I'm killing you but... I captured some footage using "DV Capture" and when I try to view it in Windows Media Player it says i'm missing a codec. I also tried to edit with it in premiere and Edius with the same error. Any ideas?
                          Originally posted by STORMDAVE
                          Also DVCapture will only work with Windows XP. .
                          Works in Vista too if you have EDIUS installed and your dongle plugged in. :)
                            Why not capture in EDIUS? (save dialogue)
                              I guess I can. I was hoping to capture all of my tapes for future use and I'm not sure I will always have access to a canopus/GV editor. Are you suggesting capturing in Edius with Microsoft DV capture setting? If so, how do I find that?
