Monaural channel (EDIUS7)
  • Monaural channel (EDIUS7)
    I'm Monaural Channel clip in Bin menu. And when add this clip to timeline, audio channel not monaural. why is this happening?
    Do you have the mapping set correctly?
      imho
      works not in the bin, for to change real the audio-properties from the clip
      in the bin it works only for to change the properties from the clip for:
      control / check the clip with these (temporally) settings in the player windows
      behind move the clip to the timelimne, these settings (because temporally) are gone
      for to change the audio-properties continuous, you must do it on the timeline
      right click on clip on timeline, and in this properties window change it to your wish
      or as "Jerry" written ...do it over channel-mapping from the sequence
      imho, the possibility to change it on the properites-windows from bin ... should to be "greyed out"
      It is not new / it was (tested) on 6.5x / it was (tested) on 6.x
      the last version who this work continuous, was (tested) Edius_5 (bevore audio-patch and so on)
      Last edited by CentralEurope; 03-02-2014, 09:20 PM. Reason: remove color from textpart and edit some typo
