Those of you who are using Blu-ray apps. ie Roxio or Encore, are you going from Edius timeline and encoding an Mpeg file or letting the HD app. do it using a Edius HQ avi. (if doing it in Edius exactly which Mpeg type file, I would be using speed encoder) Thanks. Gary
Were to encode for HD
On this forum (in ProCoder) and the Roxio forum are lots of threads about this, just search it.
With ProCoder Express and ProCoder 2/3 you can make compliant files albeit with some tweaking of the common preset.
With Speed Encoder you can not!!!!AMD Ryzen 9 5950X, AMD Radeon 6800XT, 64GB RAM, EDIUS X WG.
