Fade in/out layouter
    Please watch the attachment of the transition to the information palette.
    Maybe you can also do a screen capture to show me that it does not work? This will be very helpful.
      Originally posted by GrassValley_SL View Post
      You must have a special version of EDIUS because 2 and 3 work fine here.
      Thanks for the suggestions
      1. It works, but a work around none the less.
      Adding a fade button is the way to go.
      2. Does not work. When you save a preset as you suggest with fade in and out. It will only work if all the PIP's are the same length which they are not. I tried that one before I posted.
      3. I Stand corrected. It does work.
      And I have read the manual!
      You assume too much.
      I thought you were here to help, not demean?
        Well we all are trying to help but if all we get back that is not working there is not much in that. Anyway great that you can least get your work done.
          Thank you
          Hi Steve,
          Thank you very much in helping out!
          I am new to Edius 7 and I need to get my work done as quick as possible.
          When we work together everyone gains.
          -Dwayne Gitter
