edius 4.5 and bcf2000 not working pleace help !
  • edius 4.5 and bcf2000 not working pleace help !
    "failed to load, confirm to connect BCF200"
    ? and what ? return edius and the bfc2000 ?
    Canopus support bcf2000 so were is the minimum doc ?
    if some one have a bfc successfully working in edius please help :-)
    1 Connect unit to pc.
    1a some systems need the usb driver available from behringer
    When using the usb driver from behringer you have to turn the unit on before or during booth or your system won't booth completely.
    2 start Edius
    3 go to plugin settings
    4 go to input controller ->fader -> fader device settings choose Behringer bcf 2000
    do a reconnect
    5 Now under fader the Behringer BCF 2000 will show up
    Click to open it and you'll see the mixer layout appear
    Go to load presets in the layout and load preset 9
    apply ok.
    6 you are done.
    Note: It does not work as it does in audio apps. Only fader control and JKL work.
      ok thanks for you help
      it's not working sorry not simple :-)
      it's a bfc and firmware 1.10 (all new) it's work with ardour (audio soft) on ubuntustudio it ok
      on windows by default the slot 09 is for reason (audio soft)
      the "b-control" software see/update/change/save the .syx no probleme (not very stable but work)
      when i connect the bcf on edius 45c (i am in the midle of some work i update next week)
      it's "connect" but after it can't update "cannel" 09 or 10 or nothing
      echec de l'instalation
      comfir the conection bla bla bla
      is any were a file like a canopus.syx too load in the bcf2k ?
      or any idea ?
      (sorry bad English) :-)
        Can you try to move reason to another spot with the bcf software.
        Keep 9 empty .
        Then do the steps above.
        Because here the bcf works in EDIUS(under vista and xp on different systems) . I will look at my firmware ect tomorrow and will post details.
        Sr
          While BCF2000 is running in Edius, is the buffer falling down (like with the mixer or VST plug-ins) ?
          System : W7 Ultimate - MB: Asus Z170 - I7 6700K - Ram 16 Go - SSD1 256 Go (OS/log) - SSD2 1To (rushes) - HDD 4To (save) - Nvidia Asus GTX970 - HDspark - Edius WG 9 - Vistitle 2.6 - Robuskey - Mercalli4 - Neat video - Ignite - Hitfilm4Pro - AV : Eset Nod32 - Others : Moniteur Sony 32-EX500 - Cam : Sony EX1-R - 2 x Sony PXW-X70 - 1 x Pana GH5
          Edius in France
            thank you SRsupport :-)
            "Can you try to move reason to another spot with the bcf software.
            Keep 9 empty"
            yes i try that but not simple in b-control (Behringer soft) it's copy/paste not erase the slot 9 is free but not empty... :-)
            in a new direction maybe it's possible too put with b-control the good .syx ?
            the good edius.syx in your bcf2k, copy it with b-contol ----mail---my bcf ?
              any news ? mr. SRsupport ?
                He to be honest I forgot about this one. I'll help with this on Monday when I am behind a machine with a bcf.
                Sr
                  Use this file in EDIUS.
                  Go to plugin-> input controller -> fader Behringer bcf 2000
                  Under left choose import and import this file.
                  Sr
                    now it working ! :-)
                    thank you SRsupport for the file , it' not the good one but thank
                    the probleme is my usb2/winxp/edius but a don't have any problme but this one imposible edius feed the bfc to that file a .syx file for the precet 9 of the bfc
                    a friend upload is file from is bcf and with the soft bcedit (from beringher) i upload it too the bfc 1 try and it's work :-)
                    now edius see the bfc and work with it no problme , nice !
                    ps sorry for my strange English but if any one have a "strange" probleme whith edius and the bfc like my it could help a litlle
                    si j'ai un peu + de temps je reécrirer ca en Francais :-)
                      What is BFC 2000, for Edius ? Thank you for response.
                        The BFC2000 is a controller, it enables you to control certain functions with hardware vice using virtual controls in software also since the faders are motorized changes in the virtual will be reflected on the hardware.
                        http://www.behringer.com/BCF2000/index.cfm?lang=eng
                          Thank you for your answer,
                          and could you tell me about the controled functions ?
                          Are there only audio ones ?
                          Excuse my language !
                            The hardware fader lets you control the audio mixer levels just like you would if you were using a mouse, but it's a slighter.
                              Thank you very much.
                              Guy Leblond
