Edius SD MXF OP1a -color space?
  • Edius SD MXF OP1a -color space?
    I tried to export SD material from Edius in MXF OP1a with mpeg2 codec and I have found that exported file has wrong color space.
    For SD material that should be Rec. 601 but instead of that Edius exported MXF with Rec. 709 color space witch is used for HD.
    Am I doing something wrong in setup or this is something wrong with Edius exporter?
    Exported MXF technical spec is:
    General
    Complete name : C:\Users\Admin\Desktop\MXF.MXF
    Format : MXF
    Format profile : OP-1a
    Format settings : Closed / Complete
    File size : 21.3 MiB
    Duration : 13s 640ms
    Overall bit rate : 13.1 Mbps
    Encoded date : 2014-01-31 12:51:33.948
    Writing application : Grass Valley K.K. EDIUS 7.0
    Writing library : Grass Valley K.K. EDIUS 7.0
    Video
    Format : MPEG Video
    Format version : Version 2
    Format profile : [email protected]
    Format settings, BVOP : Yes
    Format settings, Matrix : Custom
    Format settings, GOP : M=3, N=15
    Format_Settings_Wrapping : Frame
    Codec ID : 0D01030102046001-0401020201011100
    Bit rate : 8 000 Kbps
    Width : 720 pixels
    Height : 576 pixels
    Display aspect ratio : 16:9
    Frame rate : 25.000 fps
    Standard : Component
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Top Field First
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.772
    Time code of first frame : 00:00:00:00
    Time code source : Group of pictures header
    Stream size : 13.0 MiB (61%)
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Audio #1
    Format : PCM
    Format settings, Endianness : Little
    Format_Settings_Wrapping : Frame (AES)
    Codec ID : 0D01030102060300
    Bit rate mode : Constant
    Bit rate : 1 152 Kbps
    Channel(s) : 1 channel
    Sampling rate : 48.0 KHz
    Bit depth : 24 bits
    Stream size : 1.87 MiB (9%)
    Audio #2
    Format : PCM
    Bit depth : 24 bits
    Audio #3
    Format : PCM
    Bit depth : 24 bits
    Audio #4
    Format : PCM
    Bit depth : 24 bits
    Other #1
    Type : Time code
    Format : MXF TC
    Time code settings : Striped
    Other #2
    Type : Time code
    Format : SMPTE TC
    Muxing mode : SDTI
    Edius Silver Status
    Gigabyte UD5 X58, i7 950 , 2TB RAID 0,GTX 285 PCIe, 6GB RAM DDR3 1600MHz, OS drive SSD Corsair, 750W PS,Samsung 1920x1080 LCD, GVG HD Storm 3G, Edius 7.30, Windows 7 64bit Ultimate)
    JVC DT-V20L3 20" HD-SDI broadcast monitor, multiformat
    No answer?
    Edius Silver Status
      We have confirmed this and it will be fixed in a future update.
        Thanks for info Steve,
        Regards
        Edius Silver Status
          You are welcome.
          Thanks for reporting!
