Its our first feature, edited and nearly entirely color-balanced in Edius 6. It just came back from the distributor's quality control with problems I'm not sure how to address. I'll start with the Technical Specifications they give of our film and then links to the images with the related problems. The "elevated black levels" and "inconsistent color correction" are fixed, of which were rarities. The majority is "posterization/blocking" and "incorrect line count."
I'm not privy to the lingo, but it seems that "posterisation" is a significant step from one color value to another: banding. It should be noted that the video was captured 8-bit (which displays inherent light banding), and shot in high contrast during some scenes crushing the blacks and whites, further developing banding in those areas after reversing the contrast to fit within cinema color scale. There's nothing I could do about those; the information wasn't there. If that is what they are seeing, I don't know how to correct it.
Technical Specifications & evaluation, should this mean anything to anyone:
Anybody know what these mean and how to fix them?
QC ERROR NOTE: Incorrect line count for aspect ratio (38/543) (should be 31/550 for 16x9 1.85 Letterbox). I have no idea what this means. I thought "lines" was specific to interlacing, i.e. 480i= 480 lines vertical.
QC ERROR NOTE: Solarized whites - window / door - man in store. If this is referring to the blown out whites that were dropped to make cinema safe, what does that mean I am supposed to do?
QC ERROR NOTE: Posterization error / blocking - man's shoulder
QC ERROR NOTE: Posterization error / building in background
QC ERROR NOTE: Posterization error - close up of black man
QC ERROR NOTE: Posterization error - close up of people's head (intermittent throughout scenes) (example) 1 I'm posting 4 examples from this scene because he said it occurred throughout. I don't know what I'm supposed to be seeing.
QC ERROR NOTE: Posterization error - close up of people's head (intermittent throughout scenes) (example) 2
QC ERROR NOTE: Posterization error - close up of people's head (intermittent throughout scenes) (example) 3
QC ERROR NOTE: Posterization error - close up of people's head (intermittent throughout scenes) (example) 4
Keep in mind, those who might berate my incompetence with your higher knowledge, I did not go to school for this and had to learn cinema color range by reverse-engineering other films. So a dozen problems out of 100 minute runtime, I consider a success.
BTW, I love edius for color balancing. Adobe's 3-way is inferior when it comes to speed and accessing stacked effects. The 3-way colorer is a dream. I can look at 2 images and immediately know what to change and how far. It's so fun.
Thanks,
Stephen Jay
Thanks,
Stephen Jay
