EDIUS 7 does not use a dongle. We have activation.
6.5 and 7 on the same machine
If you are going from 6.xx to 6.5x or 7.xx, the dongle will be ignored. It will more than likely install onto each drive if left in, but 6.5x and 7.x won't recognize it for anything.
The only issue that you would run into is if your GV/Canopus card had different firmware for each of these programs.
The firmware is not stored on your system drive. It is a dedicated chip on the GV card that is updated by flashing the chip.
If you don't have a GV/Canopus card, then you should be good to go with separate drives.Jerry
Main System:: Azrock z690 Taichi, [email protected], 64gb ram, Lian Li Galahad 360mm in push pull, Lian Li 011 Dynamic XL ROG case, 13 Lian Infinity fans, Win11 Pro , Samsung 980 1tb boot NVME, 2TB Sabrent M.2 NVME, 2 TB WD 850x NVME, 1TB Samsung SSD, 12TB Raid 0, BM MINI MONITOR 4K, , Dual LG 27GK65S-B 144Hz monitors, GTX 1080ti SC Black.
CMOS Checksum Error
CMOS Checksum Error
I now have two complete systems on seperate ssds
sometimes I get a CMOS Checksum Error when booting telling me about a cpu change. Once I load defaults in the bios the halt goes away. Not very elegant. Others have this isssue too?
tks
BruceBolex, Beaulieu, ArriBL, Marconi Mark IV, GE pe 250, Polaroid Land Camera, Pentax M, Nikonos, Sony AVC-3400, Sony DVR460 Fuji 7000, Fugi s602, HDR-HC1, HDR-FX7, HDR CX550v, Cx 130, GoPro, Contour, Kodak PlaySport, Sony RX100, Sony HX300, DJI Phantom, HDR-MV1, FDR-AX100, A5100, Livewedge Vision Mixer, X9 hdmi in H.265 recorder
Originally posted by LTVHD View PostDo not create a dual boot on one physical drive, it needs to be two separate physical drives, and don't have both running at the same time on the same machine. This is important as one Windows 7 drive will do things to the other, and can cause issues.
I'm running a dual boot system as logical volume with RAID 0 drives(2xSSD) with Edius 6.5 and Edius 7.x without problems what so ever.Attached Files_________________________________
Triple boot:Win10Pro/I7-5930K/GTX780/SSD-RAID/HDD-RAID/10GbE Intel X550/BMD 4K Extreme 6G/32GB RAM
Triple boot:Win10 Pro/I7-6950X/GTX1080/SSD-RAID/HDD-RAID/BMD 4K Extreme 12G/2 x 10GbE/64GB RAM
both on: 10Gbps Media sharing Network, 10Gbps NAS
As long as you install each Windows on a separate volume it's OK, though bootsector and boot manager is still shared.
Windows is installed on different partitions on the same logical volume.
As said without any problems on several systems since years now._________________________________
Originally posted by Jerry View PostMy case has a built in SSD slot. All I do is turn off, replace the drive, and start up. This takes less than a minute to do all of that.
LandonIntel i7 3970X Six Core 3.5GHz - Window 7 64 bit - 32GB DDR3 1600MHz Ram - Nvidia GTX-680 2GB GDDR5 - Storm 3G - Edius 6.52.
Originally posted by Landon View PostCan I clone my SSD system drive with Edius 6.5 to another SSD slot then install Edius 7 to new SSD (clone)? If I want to run Edius 7 just replace the drive. Any problem if I do like that? Thanks for your help.
Landon1: 3970X Threadripper, Asus ROG Strix TR40 E Gaming, G. Skill Trident Z Neo 128G DDR4 3600, EVGA GeForce RTX 2080Ti, Samsung 970 EVO M.2 1T, Intel 660P M.2 2T (2), Seagate Ironwolf NAS 12T, Enermax TR4 360 AIO, Lian Li 011 DXL, AJA Kona 4, Asus ROG Thor 1200
I would think not allowing two separate versions to run on a single machine would hurt sales.
I'm not a power user, but I am not ready to give up something stable when the only way to try another version is to remove my current version.
In my 30 years of using computers, Edius is the only program I have come across that does not allow a user to have two separate versions installed.
I also have Vegas 8. Tried Vegas 11, did not see a real need to keep it at the time, uninstalled it, Vegas 8 still there, no down down, no hassle.
Same for Photoshop versions.
Alan
There are lots of programs that don't allow you to keep earlier versions on your system. I can only assume that there are reasons why you can't with Edius. Maybe to do with hardware drivers and codecsDVC Built Clevo P775DM3-G Laptop with UHD screen, 7700K [email protected], Geforce GTX 1060 6GB GPU, 500GB M.2 Primary, 1x 480GB SSD, 1x1TB M.2, 1x 2TB 5400RPM Video drives, external Blu-ray Optical
Originally posted by Globe View PostCan I run Edius 6.05 projects in Edius 7? I assume it will convert to new format, but I want to keep the projects.
you right click the EDIUS 6.05 project file and copy/paste, then rename the pasted copy by adding E7 before the dot
then you can at any time open the original in 6.05Anton Strauss
May i offer some advice on this issue?
Buy a separate HDD and load it up with the software you need (hell, why not put other software on one HDD just in case you need it) and of course Edius 6.5 on the one and Edius 7 on the other.
You swap out the HDDs when you need to work with the data.
And of course having a USB key to swap the .EZP file around is OK rather than constantly hunting for it on the HDD after you're done with that one.
