How can I use Quick titler to make the copyright logo?
quicktitler and copyright
You can use Character Map to copy/paste what you need. (Alt+0169)
Be sure the font you use also contains the character you want!Rusty Rogers | Films
Twain - "Glances at History" 1906 -
In the Windows start menu, go to Accessories, Systems Tools, Character Map and double click on the symbol you want to use. Then click on Copy. Go to Quick Titler and paste the symbol where you want it. You can change the font in the Character Map to match the font you are using for your title before selecting it. Mostly, I just leave it on Arial.My System: Edius Workgroup 9.51 & 10.0, Intel I9-9900K 3.60GHz Liquid Cooling, MSI Z390-A PRO MB, 32-GB Mem, GeForce GTX 1660 6GB GPU, BM Intensity Pro 4K Card, Win 10 ProComment
