DVD author tool
  • DVD author tool
    Does anyone have any good tutorials on how to use the DVD author tool? Maybe if I learned all the ins and outs I would like it more.
    Randy
    That is a good question Randy. Especially now that the authoring part of Edius is fixed in 7.21. If you find a good tutorial please PM me.
    Ronnie
    Ronnie Martin
    Kato Video Productions
      In this free video tutorial, you will learn everything you need to know for a successful start with EDIUS 6 or EDIUS Neo 3, regardless if you are a new user ...
      Built right into EDIUS is a comprehensive DVD and Blu-ray authoring system that can use contents of your timeline to transcode, create chapters, add menus, a...
      Getting Started with EDIUS 6------------------------------------------video2brain, 2011Grass Valley's EDIUS is well-established as the nonlinear editor of ch...
        Ronnie
        You indicate "fixed" for the DVD authoring in EDIUS. I wonder if that/those fix(s) address the disappointment I have experienced with it.
        I created a fairly complex menu, 2 sequences each with 6 chapters. That created a main menu to select either sequence and two chapter menus, one for each sequence. Each menu had a background which I supplied. The chapter menus were motion menus. It looked great. Problem was, it played properly on one of my DVD players, It would not even load on another player, and the navigation on chapter menus wouldn't work (sometimes) on another DVD player.
        Does this sound like the sort of problem which has been fixed?
        Fred D
          I wish someone would make a DVD tool that pluged in to Edius. I really hate going to Encore.
          Randy
            I really love going to DVD Lab Pro, it is such a simple workflow from EDIUS 7 to DLP
            1. export markers using the german marker exporter
            2. export ES streams (very fast) and feed DLP
              yeah I bought that years ago it doesnt do BR though and thats key for me.
              Randy
