AVCHD 60p
  • AVCHD 60p
    Most of the new cameras today shoot in AVCHD 60p. Is Edius 6.5 and/or 7 capable of exporting in AVCHD 60p? I know earlier versions of the program only support 60i.
    simple ... YES....Edius 6.5 and 7
    you need to make first your own 60p project setting....
      Drop your footage in a 24p project for great sloMo!
        Ok just to confirm this must be a new feature from 6.02 as I see i do not have any export presets for 60p, only 60i settings.?
          That would provide better slow mo than using the Edius slo-mo function?
            Do it right and you get output without interpolation. (40%)
            My first 60p camera will be here today! (Sony HDR-AS30V)
              You can just modify any of the output presets. Take a 60i preset, check enable conversion, open the advanced settings window and set frame rate and progressive. Same way as setting up a project preset for 60P. Works in 6.07 on my second PC.
              Ron Evans
              Ron Evans
                And then you would could the slow motion section as a sequence and then reinsert into a timeline?
                  I gotta be doing something wrong, When I drop my 60P footage in a 24P project I do not get slow motion playing the timeline or exporting. Any idea what I am doing wrong.
                  Edius Workgroup 9, Edius X Workgroup, Gigabyte X299 UD4, Intel(R) Core(TM) i9-10900X CPU @ 3.70GHz, 64.0 GB Corsair Memory, Windows 10 Pro 20H2
                    Yes
                    Before placing on the timeline
                    With the clip in the BIN right click and select "Properties" and set the frame rate to 24 or what your project is
                    Then place on the timeline
                    Barry
                      Thanks Barry, that did the trick. I guess I had one of those senior moments.
