Automatic Gaps Between Clips
  • Automatic Gaps Between Clips
    Is there any easy way of putting a pre defined gap between clips on a timeline? I want to have a sequence of 20 clips with a 3 second gap between each. I know that I could do this manually, obviously, but is there any way of doing this automatically?
    System:
    Custom build PC: EDIUS 9 Pro; ASUS PRIME H310M-A Motherboard; Intel(R) Core(TM) i7-8700 CPU @ 3.20GHz; 16GB Corsair DDR3 RAM; NVIDIA GeForce GTX 1060 6GB; 500 Watt PSU, 1 x 250GB SATA2 Drive for System, 1 x 1TB and 1 x 2TB SATA2 drives for video footage; Pioneer BDR-207DBK 12x Internal BD-RW Burner; Windows 10 64 Bit
    UK & Ireland Cameraman and Video Editor
    You could make a black clip in the Bin and set its duration to your gap duration.
    Insert between your clips and you're done.
      Brilliant idea sir! Why didn't I think of that?? No, don't answer that ;)
      System:
        When you do a story board in the bin drag the color matte and press ctr (=duplicate) in the bin between the clips.
