Handbrake 1 pass 2 pass
  • Handbrake 1 pass 2 pass
    I exported a 10 second clip from Edius and converted it to mp4 with Handbrake twice... once with 1 pass and again with 2 passes. Then I brought them back into Edius and turned on and off the eye of the top one to compare... and I didn't see a difference in one single pixel. What gives?
    You would see more if you use the difference key filter!
    Andreas
    Andreas Gumm
    post production / authoring
    Windows 7 Ultimate,
    GV hardware: 3G Storm
    PC 2
    GV hardware: HD SPARK
      Andreas
      Decomb is set to default and rest are off. I don't see a difference filter.
        I meant the difference key filter in EDIUS to compare both clips!
        Andreas
        Andreas Gumm
        Windows 7 Ultimate,
        PC 2
          Andreas
          Nice idea. In programming, we use XOR, which is like the difference key in editing... I'll try it.
            XOR always wins!
            If you need to see super-subtle detail, you can apply a Chrominance filter with luma limits and boost/color anything greater than a given range.
              It would also depend on the bit rate. If the bit rate is high enough I would not expect to see a difference between a two pass and one pass encode. You need two pass to get the best out of encodes where you are trying to squeeze it a lot.
              I don't know what the "sweet spot" would be for H264 but for DVD in programs like Adobe Encore they choose constant bit rate for anything under an hour and 2 pass VBR for anything over an hour, on the basis that under an hour, at the bit rate needed to fit that on a DVD, you can't see the difference between constant and VBR.
