Ok.......I have installed Edius 4 I was previously using 3
I installed 4 on another computer since 3 is working great didn't want to touch it since it was working and always scared to upgrade just for what has happened..so here is problem
the Codecs Canopus DV and Canopus Loseless
they only work on computer I installed Edius 4 on and u have to have dongle plugged in to get them to work.....I use them in Virtualdub...sooo I want to do some work on 3 other computers preping footage to edit together in Edius or put directly into ProCoder but now I can't use the codes unless I go around plugging in the donlge to the computer I want to use the 2 codecs on??? This was not a problem with 3, I installed 3 on the computer just to get the codecs and then remove edius 3 but now I can't do this with 4??? any ideas??
thanks
Jeremy
thanks
Jeremy
