Does anyone know how to listen to audio being recorded using the Voice Over tool in Edius 4.52? I can see the audio level, but I'm not able to actually hear the audio anywhere.
Monitoring Voiceover Audio
____________________________________________
Primary System
Asus P5K64 WS, Intel QX9650, Quadro FX 1700, 2GB of OCZ 1333 Platinum DDR3 RAM, 2 x 20" Wide Viewsonics, Windows XP Pro, Edius 5, HDStorm, Seagate Barracuda ST3250310NS 250GB 7200 RPM SATA 3.0Gb/s Hard Drive, OCZ600GXSSLI 600W ATX12V SLI Power Supply
Field System:
Spartan S1730E, 4 3.6GHz NVidia Chipset, 1GB RAM, DVD+/-RW, Win XP Professional, Edius 5, 2 SATA HDDs with RAID 0/1 60GB 7200Tags: None
Yes. That way I won't have to worry about feedback.____________________________________________
Primary System
Field System:
I don't know, but I can check.
Is it that Edius 4.52 software purposely cuts the audio output during a voiceover? Back in Storm I used to be able to monitor while recording audio. Maybe I should just reload my Storm software to record audio?
I have tried using Adobe Audition but I can't seem to figure out how to configure it for one channel of voice over. There are too many things going on in that program! Does anyone have a simple Audition setup idea how to create a good audio file that can be easily imported into Edius?____________________________________________
Primary System
Field System:
The storm out is fully active during vo.
My audio card which is duplex used for monitoring. (but it is a professional audio interface )
Just so you know.
SrLast edited by SRsupport; 10-15-2007, 09:56 PM.Steve
