Title Motion Pro crashes with Edius 4.52
  • Title Motion Pro crashes with Edius 4.52
    Hello!
    We did post some problems we have some of us with Title Motion Pro that crashes everytime with the ëdius 4.52 update.
    Is there any solution for it? Why there is no followup?
    Every time I want to use TMP edius 4.52 crasches!!!!
    Is there any workaround????
    Can somebody answer PLEASE!!!!
    thanks
    Does Edius crash when you open TMP or does it crash when you exit and save?
    If crashes when you exit and save TRY SAVE AS give a name and save to disk then import it in to Edius project
    Cath
      Cath
      I did that too and it's still crashing (I want tu use roll). Thanks
        Titlemotion Pro crashes for me too. Tried the save option and everything looks fine until I come to play it back. Then Edius just vanishes from screen and has to be reloaded.
        Software:
        Edius 8.5 Workgroup
        NewBlue FX
        Hitfilm Ignite
        Vitascene 2
        Newblue TitleMotion Pro
        Smartsound 5.8
        Desktop:
        MSI Z170A M5 Motherboard, i7 6700K 4Ghz, 32GB DDR4, NVIDIA 970 4Gb, 240GB Boot SDD, 500Gb Video SSD, Windows 10 Pro 64bit
        Laptop:
        MSI GS60, 4K UHD, Intel i7, 16Gb DDR3, Nvidia 970M 3Gb, Windows 10 64bit
        Cameras:
        Panasonic HC-VX870 4K
        GoPro Hero4 Black
        Panasonic GX8 (Stills & Video)
        Garmin Virb 360
          There is a issue with Tmpro in EDIUS.
          Rolls and crawls will make EDIUS crash to desktop. (these are reported issues and are being worked on)
          For now if you want rolls and crawls in your project it is adviced to use Quick titler.
          You can use tmpro for you lower third and such.
          Note: This has been reported in other threads Crash on rolls and crawls.
          Crash doesn't happen when designing and uisng lowerthirds or graphics
          SR
            I've upgraded to 4.52 and things were good for a few days and now I'm getting the title motion crashes. It's been a real chore to get work done today. What do I have to do to get back to 4.03? I may stay there for a while. I brought in some animations that I use regularly and they even crashed.
            Henry J.
            Henry J.
            Canton OH
            www.hjptv.com
            Edius SP Supermicro X7DAE-O Dual-Core Xeon Dual Intel Xeon 5160 1333MHz 3.0GHz CPUs 4GB RAM (4x1GB) ATI Radeon HD3850 512MB Video Card
              to get back to 4.03 is not simple but worth every minute
              you must remove everything Edius/Canopus in Control panel Add/Remove and including the HX-E1 driver if using hardware
              also, in Program files, Common Files, find Canopus Shared and clear its contents after uninstalling everything Edius/Canopus
              then reboot and empty temp folder
              then install Edius 4 and reboot
              empty temp folder
              apply 4.03 update and reboot
