Hi!
I have loaded a project from canon 5d mark2.My project settings are 1920X1080 29,97p. I edit wit no problem.everything is fine.BUT!! I try to export in elementary stream for dvd (PAL) and in the following settings there is only 720X480(NTSC) If I finish my editing and then before export if I change my project settings to something like 50i instead 29,97p then in the elementary stream , will i have the settings for PAL? and most important....will I make something bad to the quality of the final video?
Please .....any advise?
thanks
thanks
