It is great to be able to higlight a range of clips and past audio/video effects into the selected clips, but why can't we do the inverse?
After a short project was completed I decided upon sweetening the audio mix which meant adding changing parameters of filters already on clip. I thought I could highlight a range, delete the existing effect (audio, or video), then copy and paste a new set of filters into the highlighted range.
I have talked to tech support about this and they said for some reason you can't delete a range of effects.
Is this true?
Thanks,
Bob
Thanks for any suggestions
Is this true?
Thanks,
Bob
