Print to Tape
  • Print to Tape
    I have a problem!
    I would like to use this in that manner the function (Print to Tape) that I give the starting timecode in EDIUS, because I don't want to set it on the deck manually.
    Is it possible?
    Hopefully, yes.
    When you start a project you can put a starting timecode.
    Project will reflect that timecode.
      if you have a Sony DV/DVCAM or HDV deck, the setup menu can be set to accept external timecode via firewire, this external timecode will be the timecode on edius timeline, providing edius setup menu is set to timeline timecode
