Hi
Could you please help me? Why is there small movement between tow key frames with similar value?
I used 3D PIP and put 4 key frames for it,
Key frame1: X=50
Key frame2: X=0
Key frame3: X=0
Key frame4: X=-50
I didn't want any movement between key frames 2 and 3 but I had, it seems that I have simple mistake but I couldn’t fix it, would you please help me?
Thanks for any help.
Key frame1: X=50
Key frame2: X=0
Key frame3: X=0
Key frame4: X=-50
