any sign of a Normalising filter in the audio side ? Anton
Dave
I agree that there is a great need for a better VST implementation for audio filters, but how can there ever be a normalizing filter in Edius, since normalizing is by definition a two-pass (i.e non real time) process?
Andrew Pinder www.chpv.co.uk Edius 9 with Blackmagic Intensity Pro 4k; Windows 10 (64 bit Pro); Gigabyte Z390 Aorus Pro; i9-9900K CPU; 32GB RAM;
I wish to find out if it is possible to nudge audio that is on a video track but unlinked from the video, I was never able to do it but I thought someone may have discovered a magic shortcut? I am able to zoom to frame level and drag it frame by frame, so it should technically be possible to nudge frame by frame
meanwhile I move the audio to audio track as I always have
You can do this (if I'm following it rightly) - you need to use the ALT key and click the outside edges of the In and Out points of the clip. (ie. manually select the outer edges of the clip instead of using the 'trim - roll'.
But then, I'm sure everyone knew this one. So the shorter answer to the REAL question here is, "no, there is no quick shortcut method."
I am aware of the alt+click the edges but it does not work
If I alt+click the edges of an audio clip on a VA track and then use , or . to nudge, the clip does not nudge, however, I noticed that the waveform (if enabled) inside the clip actually nudges without nudging the clip, this is getting more interresting by the minute, it will do the job in an unusual way
when placing the same clip on an A track, the actual clip nudges
