Exporting multible audio tracks
  • Exporting multible audio tracks
    I have not found this but is it possible to export multible audio tracks seperated from the timeline in edius ?
    It will be nice, not exporting them one at the time for ediding in audio app.
    Or get VST plugin brige that work with Waves plugins.
    my best
    JoiCam´s
    And more
    my best
    If by all means convert 2 were enough to deactivate the square channel 16 bit to exporting in "print to file" to verify you can tighten to alt+enter and to select the audio heading you verified the channels of audio there that it has that paper clip.
    I always use it when I must export the audio one of format DVCPRO HD with 8 channels of audio from EDIUS and she always respects the exit, TOTAL GREETINGS
    CSXD2 l For EDIUS Pro 6.5
