In and Out points
  • In and Out points
    On a long clip is there a way to mark multiple in and out points?
    Thanks in advance for the help.
    Hi Bobby,
    unfortunately it is not possible. I recommend that you start putting i/o points on the long clip and just add the needed clips on the timeline then start trimming and editing right on the timeline...
      In Edius 4.51c I somehow have lost my in and out points (symbols)
      When you hit i there was an in marker and o for an out marker, It works fine but lost the markers/symbols.
      Thanks in advance.
      Tony
      Tony
        If your overlay windows are to small they will be hidden. Try dragging the edge of the overlay window out a little and see if they come back OR look for a little down arrow near where they were and click on that. :)
        Remember... I and O are the keyboard short cuts for creating in and out points and ALT-I and ALT-O ar the shortcuts for deleting them individually... X will delete both at the same time.
        Hope that helped.
          when I was using 4.51c I found I had to remove some buttons in order to show all important ones, no matter how large the preview monitor was, and I had to get a red marker and paint the LCD screen where the capture and export buttons are
            Tony
            Tony
