have just downloaded 4.52. Opened a project invoked TM Pro typed in 6 lines of text set to roll. Click on save Edius crashes. Tried it 3 times still the same. Also when i set the folder first time , it is not remembered each time I open a project it asks me to set the folder. Anybody have similar probs?
possible 4.52 glitch
No problems here with a TM roll. SD 4:3 timeline 720x480.Q6600 Quad-Core2 [email protected], Asus P5K-E Wifi MB, 2GB DDR2-800 RAM, BFG 7900GTX OC 512MB, Edius NX PCI-E, Edius 4.52, Adobe Production Premium CS3, Windows XP Pro SP2
Roll Problem
I have the same problem. I can make the roll. but as soon as I try to test it in Edius it crashes Edius. 4.52Computer
Case Antec P180 - MB Intel 975XBX2 - CPU Intel Q6600
Memory 4 gig DDR2 800 - 2 Drives SATA 300 + 500
Video Card Nvidia 8800 GTS 320
I spoke with approx 10 Edius users. This is a bug. As well as most of them has a problem with Ctrl-S in Titler.Asus P8P67, Intel i7 2600K working at 4.50 Ghz, 16Gb Kingston RAM, Windows 7 64bit, 500Gb system drive, 320Gb Data drive and 1TB RAID-0 for AV, Edius NX Express, EVGA nVidia GTX 570 2.5CB DDR5, 750w ALTEC power and some creativity...
I have just installed 4.52 (an upgrade from 4.24) and it crashed my system too. On an empty timeline I created a TMP title, selected roll, then save and exit. Altho a clip appeared on the tl, no title showed up on the screen and Edius crashed after a few seconds.
Edit update: TMP still works OK, but crawl also crashes my pc. I can then only get back into Edius after restarting my pc - unable to do so via task manager.Last edited by drgagx; 10-05-2007, 11:10 AM.DVC laptop: W870CU i7; 17.3" 1920x1080; 2x 1TB 7200rpm SATA notebook drives; Edius 8.5WG; Windows 7.
It appears i am not the only one then. I do not use roll much in titles so I guess I can manage. First of all, having finished all my present projects I am going to reinstall edius with the new update from scratch.E9 PRO ,Intensity Shuttle capture Nvidia 650 TI LG 3D Monitor HDMI Win 10 PRO 64 Bit.Vistitle 2.6, Robuskey. ASUS Z370 I7 8700 16 GB Hyper X black RAM 250GB 960 EVO. 2 ITB Disks
I am also experiencing the crash problem when I try to create a crawl in TM. Three times I tried it and three times it crashed. No problem with creating a static page of text. Edius also crashes if I try to add the crawl clip to my bin (the same crawl clip which was saved somehow to my media drive - but not the bin - before crashing). The only thing I have tried to correct the problem was to reboot, but it did not solve the problem. Tonight I'll try to create a roll to see if it gives me the same problem.
Don't know if this is related to the problem or not, but when I was installing 4.52 I got dialogue boxes asking about modifying or repairing the program. I just went with the selected default settings during the install. Should there have been these dialogues? Or should the install have gone smoother?____________________________________________
Primary System
Asus P5K64 WS, Intel QX9650, Quadro FX 1700, 2GB of OCZ 1333 Platinum DDR3 RAM, 2 x 20" Wide Viewsonics, Windows XP Pro, Edius 5, HDStorm, Seagate Barracuda ST3250310NS 250GB 7200 RPM SATA 3.0Gb/s Hard Drive, OCZ600GXSSLI 600W ATX12V SLI Power Supply
Field System:
Spartan S1730E, 4 3.6GHz NVidia Chipset, 1GB RAM, DVD+/-RW, Win XP Professional, Edius 5, 2 SATA HDDs with RAID 0/1 60GB 7200
Just installed 4.52 this very second. Everything went as well as it should, no hiccups.
Opened up with all my previous projects to choose from, so opened my last one which has a still tmp title in it.
Real time changes are showing in my ext monitor :)
Now to try changing it to rolling.
Changed it to roll and it works a treat, used ctrl S and played then scrubbed timeline so fast the pc nearly took off, but no crashes here phew!!
Changed it to crawl, same again, no crash.
I haven't time to make another new project to do more testing now, but so far so good.
Graham
Installed 4.52 yesterday - all TMP working fine, rolls, crawls, live out. Also Quick Titler appears fine too.
PaulEdius Edits at: http://www.vimeo.com/user781619/videos
for whoever having problem with TMP, On the TMP window, when saving the file can you try this way: File - Export - Export ICG - ...
Then Exit - Save change - No
Open file (the one you exported/saved) on the bin then bring the title down to the timeline.Asus X99-A/USB3.1 - Samsung EVO870 1TB - Win10Pro - Edius 7.53
Installed 4.52 on my Storm 2 system today - TMPro produces only 4x3 titles, I cannot get a 16x9 title out of it at all although no crashes, or crashes with Quicktitler which seems to be working OK including ctrl S.
So, looks like there is still a bug - time for someone to collect their last cheque and move on!!
Originally posted by rbharte View PostI have the same problem. I can make the roll. but as soon as I try to test it in Edius it crashes Edius. 4.52[COLOR="Teal"]
Main System:
Edius WG 8.53, Alienware Aurora R7, 8th Gen Intel(R) Core i7,256GB M.2 PCIe Solid State Drive,(Programs ),2TB 7200RPM SATA 6Gb/s (Storage), 1TB Samsung SSD (Storage)16GB DDR4,NVIDIA(R) GeForce(R) GTX 1080 Ti with 11GB GDDR5X' 850W PSU ,Windows 10 Pro
2nd: Asus Republic of gamers Rampage 3, 6 gb, nVidia gtx, i7, win7, Edius WG 8.52 /w Spark card.
3nd: Dell precision mobile M4600 workstation i7, nVidia 2000m, Edius 6.08.
