It goes back to the accuracy and stability of the clock (crystal osciltator) in the device. Consider how accurate a typcial, economical crystal wristwatch is. Typically within a half second (12-15 frames) or so per day. That is about 1/2 frame per hour. Crystals have accuracy on the order of 10 PPM and can be trimmed and temperature compensated to be much more accurate. 10 PPM is about 1 frame per hour.
Assuming that recorder manufactureres buy similar quality crystals, one could expect similar accuracy.
Sound travels about 30 feet during one frame. A one frame sound sync issue would be roughly the same as moving 30' further (or closer) from the talent.
As to distorting the pitch, I'm not convinced that anyone can hear a difference of a couple frames per hour in an absolute sense (e.g., 1000 Hz vs 1000.02 Hz. They may be able to detect it in a relative sense if doing an A-B comparison or a mix where they can hear the a beat with a one minute period.
Consider the speed accuracy of turntables as another reference point.
