No sound from initial audio tracks
  • No sound from initial audio tracks
    I recently upgraded to Edius 6.5. See my hardware setup below. The audio is confusing me compared with Edius 5.51.
    My project is a photo montage with photographs and separate audio tracks.
    The audio file is stereo 16bit, 48kHz wav.
    The channel mapping is stereo for VA and audio tracks.
    When I initially drag audio down to audio track 1,2,or 3 there is no sound. If I delete these 3 tracks, then add a new audio track, the audio plays back fine.
    I can play the audio files in the player window and I can move the audio track to a VA track and it plays fine.
    I have tried various combinations of channel mapping, but the only thing that works is deleting the original audio tracks and adding a new audio track.
    If I load a video file with audio, the VA track plays fine, but if I map the audio to an audio track, there is no sound.
    Any suggestions other than deleting, then adding audio tracks as required?
    JimG
    System 1: Windows 7 Pro SP1, EditHD UltimaX 620Z, Edius 6.54, Vistitle 2.50, 3.8 GB Xenon Quad Core, 16GB RAM, Nvidia Quadro 4000, HD Spark, Intensity Pro, 240GB SSD System Drive, 3- 2TB Media Drives
    System 2: Windows XP SP3, Edius 5.51 Vistitle 1.8.7, P5W DH Deluxe, Core 2 Duo E6750, 2 GB RAM, EVGA GTX 460, 250 GB SATA, 500 GB RAID 0, 2-1 TB Media
    Since EDIUS 6 we have moved to a different set of ruls. I suggests that you watch the free tutorials to get up to speed with EDIUS 6.
      you may also want to look at this
      Using track patches in EDIUS6 to make it behave and feel like editing with EDIUS5
        Audio Setup in Profile
        OK. I finally figured out what I was doing wrong.
        The project preset channel mapping must show stereo (or mono) for each audio/AV track.
        I did not have any mapping selected for my A1 in the original presets.
        Thanks for all assistance.
        JimG
