What effect is there of changing project setting from 8 to 10 bit
  • What effect is there of changing project setting from 8 to 10 bit
    I have completed editing a Full HD 1920x1080 8 bit 50i project, this had colour correction etc. I read on the Forum that colour correction is best done using a 10 bit project setting. I have now changed my project setting to 1920x1080 10 bit 50i. The question I have now is will the colour correction etc. that I originally did in the 8 bit setting automatically change to the 10 bit with the project properties now set to 10 bit, or do I have to re-do the colour corrections again with the new settings?
    i7 3930K, Win 10 pro 64 Bit.
    RAM 32 GB.
    ASUS P9X79-Deluxe.
    PS Thermaltake 1kW.
    Graphics Gigabyte GTX1660 OC.
    no need to redo anything
      ....... hmmmm.....hmmmm....
      you are absolutely sure for all variants ??
      IIRC .... [shift] + [Q] produced files are not included in the automatically from Edius deletet "rendering files" behind changes from rendercodec etc. etc.
      so eventually needs " delete [shift] + [Q] produced files" per user handwork
      if he have done [shift] + [Q] in the 8bit past time......
      I am current not on the NLE-WS ... so I can test it early on european evening time....
      greetings from extremely cold and snowy easter territory....
        yes, rendered areas would need to be re-rendered, however, in Australia, we don't render
          no time to render here either - far too busy relaxing in the sun...
          Paul ;-)
            Spit my drink out on this one. You crack me up...
