Hi. When I was using Premiere it had a transition called Dip to White, which faded out one clip to the other fading to white instead of black. I've tried to find a way to do this in Edius. Can anyone help me out? It's hard to explain it so I hope it makes sense and you can follow me. Thanks.
Fade to White
Fade to White
System:
Custom build PC: EDIUS 9 Pro; ASUS PRIME H310M-A Motherboard; Intel(R) Core(TM) i7-8700 CPU @ 3.20GHz; 16GB Corsair DDR3 RAM; NVIDIA GeForce GTX 1060 6GB; 500 Watt PSU, 1 x 250GB SATA2 Drive for System, 1 x 1TB and 1 x 2TB SATA2 drives for video footage; Pioneer BDR-207DBK 12x Internal BD-RW Burner; Windows 10 64 Bit
UK & Ireland Cameraman and Video EditorTags: None
Originally posted by Alpha Video View PostHi. When I was using Premiere it had a transition called Dip to White, which faded out one clip to the other fading to white instead of black. I've tried to find a way to do this in Edius. Can anyone help me out? It's hard to explain it so I hope it makes sense and you can follow me. Thanks.System:
Sounds more complicated than it is - Whole thing takes seconds to do.Main Editing System: Sinclair ZX81 0.75Mhz chip (Overclocked to 12Ghz), Liquid Nitrogen Cooled. 48k of RAM, Compact Cassette tape drive (9600 baud), 4" B&W monitor. No keyboard - all input by thought transfer from a colander on my head. Gives me 180 layers of 4k in real time (all with 3D PIP added) and can encode and burn a 2 hour Blu Ray in just under 12 seconds. Custom editing chair that floats on magnets 2 feet above the floor. I am also able to travel in time.
Would be great to have it in the standard presets.
Newbies may not find their way to this solution.
AndreasAndreas Gumm
post production / authoring
Windows 7 Ultimate,
GV hardware: 3G Storm
PC 2
GV hardware: HD SPARK
Ahhh, but what a perfect segue to pushing them to the joys of being able to make your own effects and save them...1: 3970X Threadripper, Asus ROG Strix TR40 E Gaming, G. Skill Trident Z Neo 128G DDR4 3600, EVGA GeForce RTX 2080Ti, Samsung 970 EVO M.2 1T, Intel 660P M.2 2T (2), Seagate Ironwolf NAS 12T, Enermax TR4 360 AIO, Lian Li 011 DXL, AJA Kona 4, Asus ROG Thor 1200
I made a fade to black using a GPU effect - and you can change the black to white if you want.
http://www.dvc.uk.com/downloads/fade_to_black.zipEDIUS silver certified trainer.
A good example of DIY, David.
Perfect on black and white.
But, as Andreas said, it will be not a luxury to add some standard presets like these ones.
MarcSystem : W7 Ultimate - MB: Asus Z170 - I7 6700K - Ram 16 Go - SSD1 256 Go (OS/log) - SSD2 1To (rushes) - HDD 4To (save) - Nvidia Asus GTX970 - HDspark - Edius WG 9 - Vistitle 2.6 - Robuskey - Mercalli4 - Neat video - Ignite - Hitfilm4Pro - AV : Eset Nod32 - Others : Moniteur Sony 32-EX500 - Cam : Sony EX1-R - 2 x Sony PXW-X70 - 1 x Pana GH5
Edius in France
