Audio Mixer 4.5
  • Audio Mixer 4.5
    I have never been a great fan of the Rubber band approach to audio and I like the Audio Mixer approach.
    On the Edius audio mixer it seems I have to keep on clicking the mixer and click the proper channel. Is there a way to set up the mixer with all the tracks
    "live" so I can just ride whatever track I want without haviing to stop and re-click each track.
    Hal
    If you set the sliders in the mixer to anything other than track (click on the word track at the bottom of the slider to access the drop down menu and change it then you can ride the levels independently or together if you make them the same color at the top of the slider,otherwise track will adjust the audio levels "globally".
    Windows 10 Pro 64bit, Edius 7.53, Antec DF-85
    Corsair 850Watt P/S,ASUS P6X58DE,
    Intel Core i7 960 3.20 Ghz Bloomfield,Corsair 12 GB RAM TR3X6G1600C8D-R,PNY GeForce GTX570
    WD 600GB 10k RPM System Drive,
    WD Caviar Green Video Drives 1GBx2,G-Raid 2GB Backup Drive,Pioneer BDR-206 Blu Ray Drive
      Hal
      the rubberband method can be fun and fast if used with Y key to adjust values
