Export to tape problem ... need help please.
  • Export to tape problem ... need help please.
    Heelo All,
    I need help fairly quickly on this, if you can help. I am doing a show tonight and it is all on DVD, but as a "belt and braces" excersize I need a DV tape back up. However, when I try to export to tape I get the notice "there is no output preset to match the project settings". I have been through all the settings and tried various combinations, but it still comes up with the same fault. I am using Edius 6.08.
    Any help would be great, thanks
    Gordon.
    You need to mark in and out of your timeline, then go to Tools/MPEG TS writer and let it render your timeline into .mts so that your dv deck and understand it.
      Thanks Khoi, I will give that a try.
      Gordon
        Hey Gordon, sorry about this, it was early in the morning, I thought you were talking about HDV, no need to go through the steps I told you, you need to set a device preset, go to Settings/ system settings/hardware/device preset/new and create a new device preset for DV format, after this you can print to tape.
