How to add closed caption?
  • How to add closed caption?
    Hello people, i have 0 experience about doing closed caption.
    is there a plugin or a program we must to have to add closed caption to our videos?
    can it be done in edius?
    are there some limitations?
    I have several years editin NLE, but as i said '0 experience' on CC... any help would be great, Thanks!
    Paranova Films
    Cali - Colombia
    http://www.paranovafilms.com/
    I think you will need a third party tool.
    Here is one:
      Check your PMs. I may have some info for you. I fought this fight in 2010 with a 20 week TV program. Actually the expense and difficulty of the CC mandate by the FCC has just about killed small producers like us from producing local TV programs. I have asked several times for some help from GV in developing a solution for this problem but it seems that it is not requested enough for them to go to the expense of developing a solution. Whether or not you go with the work around that I sent you as a PM, purchase CC software, or work with a captioning company, it will be expensive, difficult and time consuming. Unless you are required to have CC by your countries FCC or the stations that are airing your project I would just leave well enough alone.
      That is just my 2 cents worth and by no means a put down on GV. I'm sure that it is simple cost of development weighed against demand.
      Take care
      Ronnie Martin
      BTW even my socks have a GV logo.
      Ronnie Martin
      Kato Video Productions
