Edius has a mind of it's own!
  • Edius has a mind of it's own!
    I have been editing just fine then....
    As I move the mouse about the timeline moves clips randomly move about.
    When I try to apply an effect, I drag it across to the timeline and bits of the media on the timeline move as the mouse goes across the screen.
    I cannot apply effects to the media, it just refuses to apply.
    Whats Happening, any ideas?
    Mark Twittey
    Walkabout TV
    Edit 1: Custom Built 3XS System, Dual Boot WinXP Pro 32bit/ Win7 Pro 64-bit,
    Asus P6T Deluxe Motherboard, Intel I7 2.66GHz CPU, Nvida GeForce GTX 580 card, LSI Raid controller,
    5Tb WD drives, 12Gb DDR3 Corsair memory, 2 x 27" ASUS LED's, Edius 7.4 & Liquid XE, Boris RED 5.4.0.378, Vistitle 2.5. New Blue Video Est.III
    Have you tried your ripple and insert settings
      I've seen that sort of behavior with some other Windows applications (But not the E6.x I am using). I suspect it is a "undocumented" Windows behavior, possibly related to the mouse in use.
      Can you try a different mouse?
        Hi:
        Restart your PC.
        Is the error still there?
        kurt
        NLE: EDIUS-X(10.34.10198)-WG​; RESOLVE-18.1.4.0009 Studio​
        // Read > Test > Understand
          Is this happening if you start a new project?
            I have done a re-boot and it's fine for one edit, then back to behaving strange
            Mark Twittey
            Walkabout TV
              Its the same if I start a new project or open an old one
              Mark Twittey
              Walkabout TV
                Have you made any OS or software updates or installed new plugins
                Can you remember as from when this happened
                Could you re load a autosave project when all was ok
                Last resort could you do a roll back
                  Graphics Card drivers? or windows update??
                  probably not, but you never know... if nothing else works out, a system restore to the day before this started might kill the bug..a bit desperate!
                  Paul :-)
                    I have made no updates or software changes.
                    I may try a rollback or old saved project.
                    Could it be a mouse or keyboard problem?
                    Mark Twittey
                    Walkabout TV
                      If it is a wireless device that uses a battery, replace the bsttery.
                        Okay a bit of a update!
                        It seems that if I want to drag someting to the timeline I have to click on it, hold for a few seconds then slowly drag the clip or effect over moving very slowly.
                        I used to be able to drag Colour Matte's now I cant?
                        Mark Twittey
                        Walkabout TV
                          Mark, a stab in the dark here.
                          I've seen similar wierd behaviours in software that turned out to be either a stuck right mouse key, or a stuck key on a keyboard. A reboot or something mechanical unsticks the offending key (or a state it has caused in the computer), and then the next time you hit that key, or combination of keys, it comes back.
                          I'd try temporarily replacing the keyboard as well as the mouse.
                            Plasma could be right...had that issue a few times, almost drove me crazy......one of my keyboard keys was stuck, and ever so often would stick and then release by itself, so I was unable to track it, until it kept stuck long enough for me to notice.....change of keyboard solved it......on my internet PC, it also happened, and another time, my mouse was getting ready to die, ..a change and it went away....If that does not solve you issue, you may have a drive that is too loaded, or running a bit slow, or heavily fragmented, or you system drive needs to get cleaned up from junk files that usually is in the 'TEMP' folder....
                              I think I will try another keyboard see if anything changes
                              If nothing try a new mouse
                              You never know?
                              Mark Twittey
                              Walkabout TV
