PAL MPEG2
  • PAL MPEG2
    I use EDIUS 6 and recently installed magic bullet looks.
    After exporting the project I tried to burn it to a disc.
    It seems like everyone turned to Smurfs.
    I need to export PAL MPEG2 .
    Many attempts were not searchable online.
    I would appreciate your help.
    I don't think that simply installing looks will adjust your footage.
      When I export the materials they look fine.
      I use the LOOKS to work faster on my projects.
      The problem begins after burning.
      The software probably exports MPEG in NTSC and i need it in PAL.
      I can't find settings for it.
      That is what i would like help with
        If your Project is Pal you will get Pal output.
        If your project is NTSC you will get NTSC.
        I have yet to see an export that turns people in to smurfs.
        I think it best if you post a screen grab and explain a little better because it is confusing as to what your issue is.
