When I used Rex, there was a shortcut to drag the audio level in all clips at the same time. Is there a shortcut in Edius? I have to rescale the audio in about 300 clips. Thanks.
Rescaling audio in all clips?
don't forget that you can raise the level of any track by opening the audio mixer and switching to track mode
also, switching the sequence setting pan mode to Edius3 compatible raises your volume to normal levels (in case you did some single audio channel panning)Anton Strauss
