I have recently purchased and installed Edius 6.52
Before commencing any serious projects I have been playing around getting the feel of using it (I was a Premiere user before)
I have a simple project using 1080/50p clips
When I place a filter such as Edge Detect or Paper on several clips they play back fine on the Edius Record Monitor and also on my TV monitor which is plugged in via a Storm 3G card
The render indicators are all orange
Then , seemingly at random, after I have tried some other simple tasks or features, one or more of the clips will have its render indicator change from orange to red when I play that clip again, and the playback on the Edius Record Monitor and the TV monitor stutters and plays back slowly
If I save and exit Edius and then re-start, at first everything is OK then later the same happens.
What I have found is that I can fix this by deleting ANY clip and then undoing that deletion. Any red render indicators then go to orange and playback is normal again
So far I cannot find any repeatable events that trigger the fault - I am still working on that but thought at this stage I'd see if anyone has anything to suggest that might be causing this, and, hopefully, a permanent cure !
My hardward configuration is
i7 3930 Processor, 32 GB RAM, 128 GB SSD, Two 2TB HDDs, Graphics Card GTX670, Storm 3G
