Edius 6: a question about Audio Mix (Peak indicator)
  • Edius 6: a question about Audio Mix (Peak indicator)
    Hi, does anybody can tell me why I have problems with Master slider on Audio Mix page? Every track AV and A are ok but when I raise the slider of volume control of Master, Edius 6 doesn't save this settings. Every time I open Edius and open Audio Mix, I always see the slider is disabled. Every time I have to adjust the slider to set audio volume. Why do I have this problem?
    CPU: Intel i9 7940X
    SSD Drive:
    that is normal, the slider is in off mode but the settings are remembered, when you switch from off to Master you will see that the levels are still correct
