Hd spark pro
  • Hd spark pro
    Hello everyone,
    After updating from Edius 6.02 to 6.08 there is no sound output on the AES of the HDSpark Pro.
    Can anyone help please ?
    Hello all,
    After some tests done i conclude that there is a bug when updating to Edius 6.08.
    I installed the card on a new pc with same configuration but this time i load the Edius 6.02 and the sound output on the AES works fine.
    When i upgrade to Edius 6.08 no sound output.
    Any advice or help will be welcome gratefully.
      No audio problems noted with my Spark card. Check if any of the default audio output mapping setting in Edius changed with the update.
        Yes I don't think this is a bug but more user error.
        Also after an update EDIUS switches to OHCI as preview device. You have to select your card again as preview device after an update.
          hi,
          i do select the hd spark as preview device but still no sound.
          When i revert back to 6.02, sound ok.
