Hi my Edius 5.5 was crashed! but i can't find the Edius disc to repair it, nor the Edius official site because I think this version is out-dated! any place I can download 5.5? Urgent!
Help!!
I think you may be unlucky
You should be able to retrieve the original E5 serial number from your registered products area
and contact customer support for your region,System Asus WS Z390 Pro MB, CPU i9 9900K, 32gb 3000mhz Ram, EVGA GTX1070TI, BM IP4K Win 10, BD Burner 1 Evo 840 and 4 Hotswap caddies
If you have registered your copy you should be able to download it from the www.grassvalley.com web site downloads section. Version 5 is there. However, if you have not registered the version, that section will not be show3n.
Originally posted by henry poonMy Edius was crashed! but I got no software disc on hand, where can I downlaod it since Edius official site seems didn't support this version already
Login to your account and download.
If you didn't register please call tech support for your region.
Now that would teach you, and all reading this post, that when you download updates of any software, always make a copy ..discs are cheap. I have copies of ALL my edius versions from Ver. 1, right up to 6.52...I download the updates, install and then make a disc just in case such should occur
Just checked and its as i saw it earlier
the download section has 5.51 and states you need to install the originall CD firstSystem Asus WS Z390 Pro MB, CPU i9 9900K, 32gb 3000mhz Ram, EVGA GTX1070TI, BM IP4K Win 10, BD Burner 1 Evo 840 and 4 Hotswap caddies
You have to install 5 first which is where your problem startedSystem Asus WS Z390 Pro MB, CPU i9 9900K, 32gb 3000mhz Ram, EVGA GTX1070TI, BM IP4K Win 10, BD Burner 1 Evo 840 and 4 Hotswap caddies
Originally posted by Alade View PostNow that would teach you, and all reading this post, that when you download updates of any software, always make a copy ..discs are cheap. I have copies of ALL my edius versions from Ver. 1, right up to 6.52...I download the updates, install and then make a disc just in case such should occur
Always archive in some manner. Websites don't last forever, neither do companies.
