Shift + Alt
  • Shift + Alt
    In Edius 4.03, shift+alt shortcut made it possible to shift all the elements on the right cursor of EACH track towards the right-hand side or the left. In the version 4.51c, shift+alt shortcut shifts only the elements of the selected track. How to make to again shift all the elements with the version 4.51c?
    1ST SYSTEM : INTEL I7-7700 / 32GO / 1 SSD NVME 256GO / 1xSSD 1TO + 2xHDD 8TO + 2xHDD 4TO / BMD Intensity Pro 4K / AMD R9-290 / Jog ShuttlePro2
    Monitors : 1x27" WQHD IPS + 4x24" WUXGA IPS + 1xMon JVC 17" TM-H1750C + 1 TV 22" FHD + 1 TV 55" 4K
    Soft : Windows 7 Pro x64 - Edius Workgroup v9.50.5351 - Vistitle v2.8.0.5 - Neat Video Denoise v5.0.1
    Enable Sync. It's next to the Ripple button in a small drop down menu.
      also, go to application settings and make sync mode the default and turn off ripple mode, this will then be applied to all new projects
        I noticed that alot of people have the same issue -- they have no clue what the Sync mode is. I think it should be a button, or just be on by default when you install a fresh copy of Edius.
          sync mode is on by default if installing Edius4 versions prior to 4.5 :)
            More would know about it if it had a visible button of timeline flag.
            Don't get me started on my Pet Peeve, Rusty
              I've tried with insert mode (shortcut insert) ON of OFF. I've tried also with ripple mode (shortcut R) ON of OFF. And combination of both. No way.
              The only trick is to select the all tracks on the right and then to move the tracks.
                you need to enable sync mode, it is a hidden option
                here is a screenshot from an older version
                  Thank you Anton. I've found it.
                  In Edius 4.51c, there is no directly button sync mode like 4.03, but it is necessary to click on the arrow “to go down” from the Insert button, and then indeed there is the sync mode.
                    I admit that sync mode is a well hidden but important tool that deserves its own unique button
